[QGIS-Developer] Issue with future 3.22 LTR ? (a.k.a missing backports to 3.22)
Julien Cabieces julien.cabieces at oslandia.com
Thu Dec 9 23:44:53 PST 2021
I confirm it's completely about forgetting. When I backported in 3.16
(queued ltr backports), I believed the backport in 3.22 was already done which
was not the case. Thank you for fixing this.
Kind regards,
Julien
> Hi Olivier,
> Yes, backporting to 3.16 implies backport to 3.22. And I think the PR you
> point here is more about forgetting. The PR itself is opened during 3.22.0
> dev cycle and merged few days after release, so easier to forget to add the
> label.
> And the list of missing PRs should actually be
> https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+queued_ltr_backports%22+-label%3A%22backport+release-3_22%22+merged%3A%3E2021-10-21
> since anything merged before 22/10/2021 is automatically in 3.22. Finally,
> there's no that much leftover PRs, so I think everybody is OK with your
> logic.
> Regards,
> Harrissou
> Le jeu. 9 déc. 2021 à 15:29, Olivier Dalang <olivier.dalang at gmail.com> a
> écrit :
>> Hi all !
>> There's something I don't completely understand with the current
>> branches/releases process and which to me looks like a major issue (came
>> across it while checking the status of a recently merged bugfix PR#45521
>> <https://github.com/qgis/QGIS/pull/45521>).
>> That fix was merged to master with the `backport queued_ltr_backports`
>> label, but without `backport release-3_22`.
>> As far as I understand, this means it will be available in 3.24 (master)
>> and in 3.16 (after some quarantine), but not in 3.22. Still if I understand
>> correctly, 3.22 is our future LTR, meaning that LTR users will at some
>> point upgrade from 3.16 to 3.22. Does that mean that the bug they have seen
>> fixed in 3.16 will be reintroduced in 3.22 ?
>> The following filter shows many other PRs backported to 3.16 but not 3.22 :
>> is:pr label:"backport queued_ltr_backports" -label:"backport release-3_22"
>> <https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+queued_ltr_backports%22+-label%3A%22backport+release-3_22%22> (same
>> search should also be done with label `backport release-3_16`)
>> Shouldn't backporting to 3.16 always imply backporting to 3.22 ? Or am I
>> missing something ?
>> Cheers !
>> Olivier
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
