[QGIS-Developer] Issue with future 3.22 LTR ? (a.k.a missing backports to 3.22)
DelazJ delazj at gmail.com
Thu Dec 9 06:53:49 PST 2021
Hi Olivier,
Yes, backporting to 3.16 implies backport to 3.22. And I think the PR you
point here is more about forgetting. The PR itself is opened during 3.22.0
dev cycle and merged few days after release, so easier to forget to add the
label.
And the list of missing PRs should actually be
https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+queued_ltr_backports%22+-label%3A%22backport+release-3_22%22+merged%3A%3E2021-10-21
since anything merged before 22/10/2021 is automatically in 3.22. Finally,
there's no that much leftover PRs, so I think everybody is OK with your
logic.
Regards,
Harrissou
Le jeu. 9 déc. 2021 à 15:29, Olivier Dalang <olivier.dalang at gmail.com> a
écrit :
> Hi all !
> There's something I don't completely understand with the current
> branches/releases process and which to me looks like a major issue (came
> across it while checking the status of a recently merged bugfix PR#45521
> <https://github.com/qgis/QGIS/pull/45521>).
> That fix was merged to master with the `backport queued_ltr_backports`
> label, but without `backport release-3_22`.
> As far as I understand, this means it will be available in 3.24 (master)
> and in 3.16 (after some quarantine), but not in 3.22. Still if I understand
> correctly, 3.22 is our future LTR, meaning that LTR users will at some
> point upgrade from 3.16 to 3.22. Does that mean that the bug they have seen
> fixed in 3.16 will be reintroduced in 3.22 ?
> The following filter shows many other PRs backported to 3.16 but not 3.22 :
> is:pr label:"backport queued_ltr_backports" -label:"backport release-3_22"
> <https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+queued_ltr_backports%22+-label%3A%22backport+release-3_22%22> (same
> search should also be done with label `backport release-3_16`)
> Shouldn't backporting to 3.16 always imply backporting to 3.22 ? Or am I
> missing something ?
> Cheers !
> Olivier
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211209/51db86c1/attachment.html>
More information about the QGIS-Developer mailing list
