[QGIS-Developer] Docker pull rate limit / Travis
pathmapper pathmapper at posteo.de
Mon Jan 4 00:57:27 PST 2021
due to the recently introduced docker pull rate limits there are
currently quite a lot Travis builds failing because of such a limit.
According to this blogpost:
https://www.docker.com/blog/what-you-need-to-know-about-upcoming-docker-hub-rate-limiting/
"[...] non-commercial open source projects can apply for a sponsored
Open Source Docker account by filling out this application. No pull rate
restrictions will be applied to namespaces approved as non-commercial
Open Source projects."
Don't know if such an application for a sponsored Open Source Docker
account would be something the QGIS project would be interested in or if
the QGIS Docker account is already sponsored. A sponsored Docker account
might help a little bit reaching these limits e.g. regarding pulling:
https://hub.docker.com/r/qgis/qgis3-build-deps
Cheers,
pathmapper
More information about the QGIS-Developer mailing list
