[QGIS-Developer] Travis failing in QGIS-Documentation
DelazJ delazj at gmail.com
Sun Jan 10 06:48:30 PST 2021
Hi devs,
Just to report that the master code tests infrastructure in
QGIS-Documentation seems broken. This is likely not due to some sample
codes in the docs since we did not change code recently, and the tests not
just run I suspect it's something in QGIS code or in the docker image; the
setup code fails with "ModuleNotFoundError: no module named qgis".
https://github.com/qgis/QGIS-Documentation/actions?query=workflow%3A%22Doctest+build%22+branch%3Amaster+event%3Apush
3.16 is running fine afaict.
Thanks for any help/fix,
Harrissou
Le ven. 9 oct. 2020 à 15:08, DelazJ <delazj at gmail.com> a écrit :
> Hi Matteo,
> I had opened an issue report to provide instructions on how to build the
> doctest (https://github.com/qgis/QGIS-Documentation/issues/6064). And I
> just noticed (sorry!) that Alessandro provided some feedback (in substance,
> "docker is the best route now").
> regards,
> Harrissou
> Le jeu. 8 oct. 2020 à 08:16, matteo <matteo.ghetta at gmail.com> a écrit :
>> Hi Harrissou,
>> I don't have any answer for that, but it is the SAME error I have on my
>> local machine with a compiled version (or even the installation from
>> package) of QGIS.
>> The only way for me to run the tests locally if using docker.
>> I'm taking advantages of your mail to raise this problem (again) :)
>> Cheers and thanks
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210110/c97ae821/attachment.html>
More information about the QGIS-Developer mailing list
