[QGIS-Developer] Travis failing in QGIS-Documentation
Matthias Kuhn matthias at opengis.ch
Sun Jan 10 09:07:42 PST 2021
It seems that something is broken in building the "custom widgets qt
creator plugin" and that our CI didn't detect that.
Part 1 : make sure this doesn't happen again. The ci builds now with
customwidgets: https://github.com/qgis/QGIS/pull/40929
Part 2 : fix the build
Matthias
On Sun, Jan 10, 2021 at 3:48 PM DelazJ <delazj at gmail.com> wrote:
> Hi devs,
> Just to report that the master code tests infrastructure in
> QGIS-Documentation seems broken. This is likely not due to some sample
> codes in the docs since we did not change code recently, and the tests not
> just run I suspect it's something in QGIS code or in the docker image; the
> setup code fails with "ModuleNotFoundError: no module named qgis".
> https://github.com/qgis/QGIS-Documentation/actions?query=workflow%3A%22Doctest+build%22+branch%3Amaster+event%3Apush
> 3.16 is running fine afaict.
> Thanks for any help/fix,
> Harrissou
> Le ven. 9 oct. 2020 à 15:08, DelazJ <delazj at gmail.com> a écrit :
>> Hi Matteo,
>> I had opened an issue report to provide instructions on how to build the
>> doctest (https://github.com/qgis/QGIS-Documentation/issues/6064). And I
>> just noticed (sorry!) that Alessandro provided some feedback (in substance,
>> "docker is the best route now").
>> regards,
>> Harrissou
>> Le jeu. 8 oct. 2020 à 08:16, matteo <matteo.ghetta at gmail.com> a écrit :
>>> Hi Harrissou,
>>> I don't have any answer for that, but it is the SAME error I have on my
>>> local machine with a compiled version (or even the installation from
>>> package) of QGIS.
>>> The only way for me to run the tests locally if using docker.
>>> I'm taking advantages of your mail to raise this problem (again) :)
>>> Cheers and thanks
>>> Matteo
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210110/87bf1ee7/attachment-0001.html>
More information about the QGIS-Developer mailing list
