[QGIS-Developer] Travis failing in QGIS-Documentation
Matthias Kuhn
matthias at opengis.ch
Sun Jan 10 13:12:41 PST 2021
Part 3 : make sure if the build fails docker images are not published in
the future
On Sun, Jan 10, 2021 at 6:07 PM Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi,
> It seems that something is broken in building the "custom widgets qt
> creator plugin" and that our CI didn't detect that.
> Part 1 : make sure this doesn't happen again. The ci builds now with
> customwidgets: https://github.com/qgis/QGIS/pull/40929
> Part 2 : fix the build
> Matthias
> On Sun, Jan 10, 2021 at 3:48 PM DelazJ <delazj at gmail.com> wrote:
>> Hi devs,
>> Just to report that the master code tests infrastructure in
>> QGIS-Documentation seems broken. This is likely not due to some sample
>> codes in the docs since we did not change code recently, and the tests not
>> just run I suspect it's something in QGIS code or in the docker image; the
>> setup code fails with "ModuleNotFoundError: no module named qgis".
>> https://github.com/qgis/QGIS-Documentation/actions?query=workflow%3A%22Doctest+build%22+branch%3Amaster+event%3Apush
>> 3.16 is running fine afaict.
>> Thanks for any help/fix,
>> Harrissou
>> Le ven. 9 oct. 2020 à 15:08, DelazJ <delazj at gmail.com> a écrit :
>>> Hi Matteo,
>>> I had opened an issue report to provide instructions on how to build the
>>> doctest (https://github.com/qgis/QGIS-Documentation/issues/6064). And I
>>> just noticed (sorry!) that Alessandro provided some feedback (in substance,
>>> "docker is the best route now").
>>> regards,
>>> Harrissou
>>> Le jeu. 8 oct. 2020 à 08:16, matteo <matteo.ghetta at gmail.com> a écrit :
>>>> Hi Harrissou,
>>>> I don't have any answer for that, but it is the SAME error I have on my
>>>> local machine with a compiled version (or even the installation from
>>>> package) of QGIS.
>>>> The only way for me to run the tests locally if using docker.
>>>> I'm taking advantages of your mail to raise this problem (again) :)
>>>> Cheers and thanks
>>>> Matteo
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210110/72627c35/attachment.html>
