[QGIS-Developer] Travis failing in QGIS-Documentation
DelazJ delazj at gmail.com
Tue Jan 12 01:55:22 PST 2021
Back to green. Thanks, Matthias.
Harrissou
Le dim. 10 janv. 2021 à 22:12, Matthias Kuhn <matthias at opengis.ch> a écrit :
> Part 3 : make sure if the build fails docker images are not published in
> the future
> On Sun, Jan 10, 2021 at 6:07 PM Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi,
>> It seems that something is broken in building the "custom widgets qt
>> creator plugin" and that our CI didn't detect that.
>> Part 1 : make sure this doesn't happen again. The ci builds now with
>> customwidgets: https://github.com/qgis/QGIS/pull/40929
>> Part 2 : fix the build
>> Matthias
>> On Sun, Jan 10, 2021 at 3:48 PM DelazJ <delazj at gmail.com> wrote:
>>> Hi devs,
>>> Just to report that the master code tests infrastructure in
>>> QGIS-Documentation seems broken. This is likely not due to some sample
>>> codes in the docs since we did not change code recently, and the tests not
>>> just run I suspect it's something in QGIS code or in the docker image; the
>>> setup code fails with "ModuleNotFoundError: no module named qgis".
>>> https://github.com/qgis/QGIS-Documentation/actions?query=workflow%3A%22Doctest+build%22+branch%3Amaster+event%3Apush
>>> 3.16 is running fine afaict.
>>> Thanks for any help/fix,
>>> Harrissou
>>> Le ven. 9 oct. 2020 à 15:08, DelazJ <delazj at gmail.com> a écrit :
>>>> Hi Matteo,
>>>> I had opened an issue report to provide instructions on how to build
>>>> the doctest (https://github.com/qgis/QGIS-Documentation/issues/6064).
>>>> And I just noticed (sorry!) that Alessandro provided some feedback (in
>>>> substance, "docker is the best route now").
>>>> regards,
>>>> Harrissou
>>>> Le jeu. 8 oct. 2020 à 08:16, matteo <matteo.ghetta at gmail.com> a écrit :
>>>>> Hi Harrissou,
>>>>> I don't have any answer for that, but it is the SAME error I have on my
>>>>> local machine with a compiled version (or even the installation from
>>>>> package) of QGIS.
>>>>> The only way for me to run the tests locally if using docker.
>>>>> I'm taking advantages of your mail to raise this problem (again) :)
>>>>> Cheers and thanks
>>>>> Matteo
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210112/9ed2380f/attachment-0001.html>
More information about the QGIS-Developer mailing list
