[QGIS-Developer] Question on @atlas_featureid
Andreas Neumann a.neumann at carto.net
Thu Jul 8 01:30:08 PDT 2021
I haven't worked on an Atlas for a while, now again in QGIS 3.16.
I was surprised to see that @atlas_featureid is not equal to the primary
key of the atlas coverage layer.
Is this expected or a bug? I know, I can access the primary key through
attribute(@atlas_feature,'pkey_name'), but it is a little more
complicated than @atlas_featureid - and I'm pretty sure that
@atlas_featureid was using the pkey column in th past?
My data source for the atlas coverage layer is a Postgis View.
Thanks if you have any info on this issue,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/fa6008ad/attachment.html>
More information about the QGIS-Developer mailing list
