[QGIS-Developer] Question on @atlas_featureid
Jürgen E. Fischer jef at norbit.de
Thu Jul 8 01:42:28 PDT 2021
Hi Andreas,
On Thu, 08. Jul 2021 at 10:30:08 +0200, Andreas Neumann wrote:
> attribute(@atlas_feature,'pkey_name'), but it is a little more complicated
> than @atlas_featureid - and I'm pretty sure that @atlas_featureid was using
> the pkey column in th past?
> My data source for the atlas coverage layer is a Postgis View.
It's probably not using the column you expect for the feature id.  Did you
specify the key column when adding the view?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/858985f5/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210708/858985f5/attachment.ksh>
More information about the QGIS-Developer mailing list
