[QGIS-Developer] Loading many Excel-Files in QGIS with correct encoding
Andreas Neumann a.neumann at carto.net
Thu Jul 15 00:11:28 PDT 2021
Seems like when I load the same file from the newer .xlsx format then
the encoding is fine.
Now I need to find a way how to batch-convert all of the many .xls to
.xlsx files automatically.
Still I find it disturbing that QGIS doesn't allow me to load the older
.xls files with correct encoding without manual intervention.
Andreas
On 2021-07-15 08:56, Andreas Neumann wrote:
> Hi again,
> I tried to set the layer encoding after the layer merging, but it fails
> And before the layer merging I cannot set the encoding in the model,
> because it only accepts a single layer as input, and not multiple
> layers.
> So it seems that I will have to set the correct encoding right away
> from the beginning on - but I don't know how.
> Thanks,
> Andreas
> On 2021-07-15 08:33, Andreas Neumann wrote:
>> Hi,
>> I have a bunch of MS Excel .xls files in the old format (hundreds of
>> files), not the new .xlsx format.
>> The content of the .xls files seems to be UTF-8 encoded, but QGIS
>> loads them with some LATIN-x encoding - all of the
>> non-ASCII-characters look garbled.
>> I want to process these files with Processing and merge them into one
>> file.
>> Is there any way how I can load these files with the correct UTF-8
>> encoding? I know, there is an algorithm to set the correct encoding of
>> a layer in processing, but unfortunately this doesn't work with
>> multi-layer input, only with single layer input.
>> Is there some OGR trick (environment variable or opening option) to
>> load the files with correct encoding?
>> Thanks if you have any hint,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210715/e3f8a24a/attachment.html>
More information about the QGIS-Developer mailing list
