[QGIS-Developer] Loading many Excel-Files in QGIS with correct encoding
Nyall Dawson nyall.dawson at gmail.com
Thu Jul 15 00:33:32 PDT 2021
On Thu, 15 Jul 2021 at 17:12, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Seems like when I load the same file from the newer .xlsx format then the encoding is fine.
> Now I need to find a way how to batch-convert all of the many .xls to .xlsx files automatically.
> Still I find it disturbing that QGIS doesn't allow me to load the older .xls files with correct encoding without manual intervention.
Isn't this limitation ultimately that GDAL isn't reading the encoding
correctly? (Or perhaps it's a limitation in the underlying freexl
library...)
Nyall
> Andreas
> On 2021-07-15 08:56, Andreas Neumann wrote:
> Hi again,
> I tried to set the layer encoding after the layer merging, but it fails ;-(
> And before the layer merging I cannot set the encoding in the model, because it only accepts a single layer as input, and not multiple layers.
> So it seems that I will have to set the correct encoding right away from the beginning on - but I don't know how.
> Thanks,
> Andreas
> On 2021-07-15 08:33, Andreas Neumann wrote:
> Hi,
> I have a bunch of MS Excel .xls files in the old format (hundreds of files), not the new .xlsx format.
> The content of the .xls files seems to be UTF-8 encoded, but QGIS loads them with some LATIN-x encoding - all of the non-ASCII-characters look garbled.
> I want to process these files with Processing and merge them into one file.
> Is there any way how I can load these files with the correct UTF-8 encoding? I know, there is an algorithm to set the correct encoding of a layer in processing, but unfortunately this doesn't work with multi-layer input, only with single layer input.
> Is there some OGR trick (environment variable or opening option) to load the files with correct encoding?
> Thanks if you have any hint,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
