[QGIS-Developer] PyQGIS Cookbook License
Malte Ziebarth ziebarth at gfz-potsdam.de
Tue Jul 20 02:40:24 PDT 2021
thanks a lot for the reply and forwarding to the PSC.
Also, thanks to the PSC for quickly adressing the issue. I'm going to
jump threads
here a little to reply also to Marco Bernasocchi's e-mail:
> Even Though the cookbook has a lot of code, we decided to license it under
> a documentation license and not a software license, since the code is
> mostly for documentation purposes and are considered "trivial code":
I think that the code being "trivial" is the crucial information to
answer my question.
Following up on that, I think that a similar statement at the beginning
of the Cookbook
documentation would be very helpful for users in a situation similar to
mine. I.e. a small
statement that explicitly tells the (developing) user that the code is
considered trivial
and may be reused in GPL'ed QGIS plugins.
Otherwise I think that deciding whether some code is trivial is not a
trivial task - at
least I did not experience it to be so.
Thanks again!
Best regards
Malte
On 03.07.21 23:35, Alexandre Neto wrote:
> Hi,
> Although I think you can safely use and replicate any part of the
> documentation, including code snippets, I think you spotted an
> important issue.
> I do believe we should add a licence to all our documentation. Maybe a
> creative commons license.
> I have included the PSC mailing list in this reply, maybe they already
> have a position about this subject.
> Alexandre Neto
> A sexta, 2/07/2021, 18:30, Malte Ziebarth <ziebarth at gfz-potsdam.de
> <mailto:ziebarth at gfz-potsdam.de>> escreveu:
>     Dear all,
>     first off, thank you all for all the great work that went into QGIS!
>     I am currently writing a Python plugin that I intend to make publicly
>     available in the plugin repository. I started developing the plugin by
>     adapting the examples from the PyQGIS Cookbook, specifically this
>     page:
>     https://docs.qgis.org/3.16/en/docs/pyqgis_developer_cookbook/plugins/plugins.html#writing-a-plugin
>     <https://docs.qgis.org/3.16/en/docs/pyqgis_developer_cookbook/plugins/plugins.html#writing-a-plugin>
>     Now the problem that I encountered with that is the license of the
>     skeleton
>     code (i.e. __init__.py and mainPlugin.py). The code does not
>     actually contain
>     a license header and the documentation page itself contains only the
>     very general copyright information
>     "© Copyright 2002-now, QGIS project. Last updated on Jul 02, 2021
>     09:02."
>     with no further licensing information.
>     I guess that the intention of this part of documentation is for
>     people to
>     have an easy start developing plugins which can then be
>     contributed back
>     to the community under GPL license. This is just what I am planning to
>     do. However, trying to put this into a correct license header is
>     currently
>     giving me a bit of a headache.
>     Maybe someone here in this mailing list has some advice about this
>     issue,
>     and maybe even the person/people who wrote this piece of code can
>     clarify?
>     Any help would be greatly appreciated!
>     Kind regards
>     Malte Ziebarth
>     Malte J. Ziebarth
>     Section 2.6
>     Tel.: +49 (0)331/288-28634
>     E-Mail:ziebarth at gfz-potsdam.de  <mailto:ziebarth at gfz-potsdam.de>
>     ___________________________________
>     Helmholtz-Zentrum Potsdam
>     Deutsches GeoForschungsZentrum GFZ
>     Stiftung des öff. Rechts Land Brandenburg
>     Telegrafenberg, 14473 Potsdam
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe:
Malte J. Ziebarth
Section 2.6
E-Mail: ziebarth at gfz-potsdam.de
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210720/3fed7696/attachment-0001.html>
More information about the QGIS-Developer mailing list
