[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Hernán De Angelis variablestarlight at gmail.com
Tue Mar 2 00:51:50 PST 2021
On 2021-03-02 09:48, Alexandre Neto wrote:
> Might seem obvious, but have you tried using a brand new profile?
Yes, I just forgot to add that to the description below.
/H.
> A terça, 2/03/2021, 08:34, Hernán De Angelis
> <variablestarlight at gmail.com <mailto:variablestarlight at gmail.com>>
> escreveu:
>     Hi,
>     I wrote about this a few days ago in the user list but I still
>     have the
>     problem and can find neither a cause nor a solution. I thus post
>     it in
>     this list in the hope that some developer may have a hint on what is
>     going wrong here.
>     In my installation the Voronoi Polygon tool is missing from the
>     Processing menu, both from the bar (vector geometry dialog) and the
>     processing panel. It is also not listed in the Python console (see
>     below
>     whole listing).
>     But, the code seems to be present in the /usr/local/share... folder,
>     where other plugins live as well:
>     localhost:/usr/local # find ./share -name *oronoi*
>     ./share/qgis/python/plugins/processing/algs/grass7/description/v.voronoi.skeleton.txt
>     ./share/qgis/python/plugins/processing/algs/grass7/description/v.voronoi.txt
>     ./share/qgis/python/plugins/processing/algs/grass7/ext/v_voronoi.py
>     ./share/qgis/python/plugins/processing/algs/qgis/VoronoiPolygons.py
>     ./share/qgis/python/plugins/processing/algs/qgis/voronoi.py
>     I compile QGIS from source, things have gone smoothly every time
>     and I
>     cannot see any obvious particular problem. I have tested with
>     master a
>     couple of weeks ago, then 3.18.0 a couple of days ago, and moments
>     ago
>     with 3.16.4 (after wiping all traces of previous installations)
>     but the
>     problem persists.
>     Anyone has seen this? What could possibly be wrong here?
>     Thanks in advance,
>     Hernán
>     from qgis import processing
>     for alg in QgsApplication.processingRegistry().algorithms():
>          print(alg.id <http://alg.id>(), "->", alg.displayName())
>     native:addautoincrementalfield -> Add autoincremental field
>     native:addfieldtoattributestable -> Add field to attributes table
>     native:adduniquevalueindexfield -> Add unique value index field
>     native:addxyfields -> Add X/Y fields to layer
>     native:affinetransform -> Affine transform
>     native:aggregate -> Aggregate
>     native:angletonearest -> Align points to features
>     native:antimeridiansplit -> Geodesic line split at antimeridian
>     native:arrayoffsetlines -> Array of offset (parallel) lines
>     native:arraytranslatedfeatures -> Array of translated features
>     native:aspect -> Aspect
>     native:assignprojection -> Assign projection
>     native:atlaslayouttoimage -> Export atlas layout as image
>     native:atlaslayouttopdf -> Export atlas layout as PDF
>     native:bookmarkstolayer -> Convert spatial bookmarks to layer
>     native:boundary -> Boundary
>     native:boundingboxes -> Bounding boxes
>     native:buffer -> Buffer
>     native:bufferbym -> Variable width buffer (by M value)
>     native:calculatevectoroverlaps -> Overlap analysis
>     native:categorizeusingstyle -> Create categorized renderer from styles
>     native:cellstatistics -> Cell statistics
>     native:centroids -> Centroids
>     native:clip -> Clip
>     native:collect -> Collect geometries
>     native:combinestyles -> Combine style databases
>     native:condition -> Conditional branch
>     native:converttocurves -> Convert to curved geometries
>     native:convexhull -> Convex hull
>     native:countpointsinpolygon -> Count points in polygon
>     native:createattributeindex -> Create attribute index
>     native:createconstantrasterlayer -> Create constant raster layer
>     native:createdirectory -> Create directory
>     native:creategrid -> Create grid
>     native:createpointslayerfromtable -> Create points layer from table
>     native:createrandombinomialrasterlayer -> Create random raster layer
>     (binomial distribution)
>     native:createrandomexponentialrasterlayer -> Create random raster
>     layer
>     (exponential distribution)
>     native:createrandomgammarasterlayer -> Create random raster layer
>     (gamma
>     distribution)
>     native:createrandomgeometricrasterlayer -> Create random raster layer
>     (geometric distribution)
>     native:createrandomnegativebinomialrasterlayer -> Create random
>     raster
>     layer (negative binomial distribution)
>     native:createrandomnormalrasterlayer -> Create random raster layer
>     (normal distribution)
>     native:createrandompoissonrasterlayer -> Create random raster layer
>     (poisson distribution)
>     native:createrandomuniformrasterlayer -> Create random raster layer
>     (uniform distribution)
>     native:createspatialindex -> Create spatial index
>     native:dbscanclustering -> DBSCAN clustering
>     native:deleteduplicategeometries -> Delete duplicate geometries
>     native:deleteholes -> Delete holes
>     native:densifygeometries -> Densify by count
>     native:densifygeometriesgivenaninterval -> Densify by interval
>     native:detectvectorchanges -> Detect dataset changes
>     native:difference -> Difference
>     native:dissolve -> Dissolve
>     native:dropgeometries -> Drop geometries
>     native:dropmzvalues -> Drop M/Z values
>     native:equaltofrequency -> Equal to frequency
>     native:explodehstorefield -> Explode HStore Field
>     native:explodelines -> Explode lines
>     native:extendlines -> Extend lines
>     native:extenttolayer -> Create layer from extent
>     native:extractbinary -> Extract binary field
>     native:extractbyattribute -> Extract by attribute
>     native:extractbyexpression -> Extract by expression
>     native:extractbyextent -> Extract/clip by extent
>     native:extractbylocation -> Extract by location
>     native:extractmvalues -> Extract M values
>     native:extractspecificvertices -> Extract specific vertices
>     native:extractvertices -> Extract vertices
>     native:extractzvalues -> Extract Z values
>     native:fieldcalculator -> Field calculator
>     native:filedownloader -> Download file
>     native:fillnodata -> Fill NoData cells
>     native:filter -> Feature filter
>     native:filterbygeometry -> Filter by geometry type
>     native:filterlayersbytype -> Filter layers by type
>     native:filterverticesbym -> Filter vertices by M value
>     native:filterverticesbyz -> Filter vertices by Z value
>     native:fixgeometries -> Fix geometries
>     native:flattenrelationships -> Flatten relationship
>     native:forcerhr -> Force right-hand-rule
>     native:fuzzifyrastergaussianmembership -> Fuzzify raster (gaussian
>     membership)
>     native:fuzzifyrasterlargemembership -> Fuzzify raster (large
>     membership)
>     native:fuzzifyrasterlinearmembership -> Fuzzify raster (linear
>     membership)
>     native:fuzzifyrasternearmembership -> Fuzzify raster (near membership)
>     native:fuzzifyrasterpowermembership -> Fuzzify raster (power
>     membership)
>     native:fuzzifyrastersmallmembership -> Fuzzify raster (small
>     membership)
>     native:generatepointspixelcentroidsinsidepolygons -> Generate points
>     (pixel centroids) inside polygons
>     native:geometrybyexpression -> Geometry by expression
>     native:greaterthanfrequency -> Greater than frequency
>     native:highestpositioninrasterstack -> Highest position in raster
>     stack
>     native:hillshade -> Hillshade
>     native:hublines -> Join by lines (hub lines)
>     native:importphotos -> Import geotagged photos
>     native:interpolatepoint -> Interpolate point on line
>     native:intersection -> Intersection
>     native:joinattributesbylocation -> Join attributes by location
>     native:joinattributestable -> Join attributes by field value
>     native:joinbynearest -> Join attributes by nearest
>     native:kmeansclustering -> K-means clustering
>     native:layertobookmarks -> Convert layer to spatial bookmarks
>     native:lessthanfrequency -> Less than frequency
>     native:linedensity -> Line density
>     native:lineintersections -> Line intersections
>     native:linesubstring -> Line substring
>     native:loadlayer -> Load layer into project
>     native:lowestpositioninrasterstack -> Lowest position in raster stack
>     native:meancoordinates -> Mean coordinate(s)
>     native:mergelines -> Merge lines
>     native:mergevectorlayers -> Merge vector layers
>     native:minimumenclosingcircle -> Minimum enclosing circles
>     native:multiparttosingleparts -> Multipart to singleparts
>     native:multiringconstantbuffer -> Multi-ring buffer (constant
>     distance)
>     native:nearestneighbouranalysis -> Nearest neighbour analysis
>     native:offsetline -> Offset lines
>     native:orderbyexpression -> Order by expression
>     native:orientedminimumboundingbox -> Oriented minimum bounding box
>     native:orthogonalize -> Orthogonalize
>     native:package -> Package layers
>     native:pixelstopoints -> Raster pixels to points
>     native:pixelstopolygons -> Raster pixels to polygons
>     native:pointonsurface -> Point on surface
>     native:pointsalonglines -> Points along geometry
>     native:pointtolayer -> Create layer from point
>     native:poleofinaccessibility -> Pole of inaccessibility
>     native:polygonfromlayerextent -> Extract layer extent
>     native:polygonize -> Polygonize
>     native:polygonstolines -> Polygons to lines
>     native:postgisexecutesql -> PostgreSQL execute SQL
>     native:printlayoutmapextenttolayer -> Print layout map extent to layer
>     native:printlayouttoimage -> Export print layout as image
>     native:printlayouttopdf -> Export print layout as PDF
>     native:projectpointcartesian -> Project points (Cartesian)
>     native:promotetomulti -> Promote to multipart
>     native:raiseexception -> Raise exception
>     native:raisewarning -> Raise warning
>     native:randomextract -> Random extract
>     native:randompointsinextent -> Random points in extent
>     native:randompointsinpolygons -> Random points in polygons
>     native:randompointsonlines -> Random points on lines
>     native:rasterbooleanand -> Raster boolean AND
>     native:rasterize -> Convert map to raster
>     native:rasterlayerstatistics -> Raster layer statistics
>     native:rasterlayeruniquevaluesreport -> Raster layer unique values
>     report
>     native:rasterlayerzonalstats -> Raster layer zonal statistics
>     native:rasterlogicalor -> Raster boolean OR
>     native:rastersampling -> Sample raster values
>     native:rastersurfacevolume -> Raster surface volume
>     native:reclassifybylayer -> Reclassify by layer
>     native:reclassifybytable -> Reclassify by table
>     native:rectanglesovalsdiamonds -> Rectangles, ovals, diamonds
>     native:refactorfields -> Refactor fields
>     native:removeduplicatesbyattribute -> Delete duplicates by attribute
>     native:removeduplicatevertices -> Remove duplicate vertices
>     native:removenullgeometries -> Remove null geometries
>     native:renamelayer -> Rename layer
>     native:renametablefield -> Rename field
>     native:repairshapefile -> Repair Shapefile
>     native:reprojectlayer -> Reproject layer
>     native:rescaleraster -> Rescale raster
>     native:reverselinedirection -> Reverse line direction
>     native:rotatefeatures -> Rotate
>     native:roundrastervalues -> Round raster
>     native:ruggednessindex -> Ruggedness index
>     native:savefeatures -> Save vector features to file
>     native:savelog -> Save log to file
>     native:saveselectedfeatures -> Extract selected features
>     native:segmentizebymaxangle -> Segmentize by maximum angle
>     native:segmentizebymaxdistance -> Segmentize by maximum distance
>     native:selectbylocation -> Select by location
>     native:serviceareafromlayer -> Service area (from layer)
>     native:serviceareafrompoint -> Service area (from point)
>     native:setlayerencoding -> Set layer encoding
>     native:setlayerstyle -> Set layer style
>     native:setmfromraster -> Set M value from raster
>     native:setmvalue -> Set M value
>     native:setprojectvariable -> Set project variable
>     native:setzfromraster -> Drape (set Z value from raster)
>     native:setzvalue -> Set Z value
>     native:shortestpathlayertopoint -> Shortest path (layer to point)
>     native:shortestpathpointtolayer -> Shortest path (point to layer)
>     native:shortestpathpointtopoint -> Shortest path (point to point)
>     native:shpencodinginfo -> Extract Shapefile encoding
>     native:simplifygeometries -> Simplify
>     native:singlesidedbuffer -> Single sided buffer
>     native:slope -> Slope
>     native:smoothgeometry -> Smooth
>     native:snapgeometries -> Snap geometries to layer
>     native:snappointstogrid -> Snap points to grid
>     native:spatialiteexecutesql -> SpatiaLite execute SQL
>     native:spatialiteexecutesqlregistered -> SpatiaLite execute SQL
>     (registered DB)
>     native:splitfeaturesbycharacter -> Split features by character
>     native:splitlinesbylength -> Split lines by maximum length
>     native:splitvectorlayer -> Split vector layer
>     native:splitwithlines -> Split with lines
>     native:stringconcatenation -> String concatenation
>     native:stylefromproject -> Create style database from project
>     native:subdivide -> Subdivide
>     native:sumlinelengths -> Sum line lengths
>     native:swapxy -> Swap X and Y coordinates
>     native:symmetricaldifference -> Symmetrical difference
>     native:taperedbuffer -> Tapered buffers
>     native:tinmeshcreation -> TIN Mesh Creation
>     native:transect -> Transect
>     native:translategeometry -> Translate
>     native:truncatetable -> Truncate table
>     native:union -> Union
>     native:wedgebuffers -> Create wedge buffers
>     native:writevectortiles_mbtiles -> Write Vector Tiles (MBTiles)
>     native:writevectortiles_xyz -> Write Vector Tiles (XYZ)
>     native:zonalhistogram -> Zonal histogram
>     native:zonalstatistics -> Zonal statistics
>     native:zonalstatisticsfb -> Zonal statistics
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210302/20e97c0a/attachment-0001.html>
More information about the QGIS-Developer mailing list
