[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Richard Duivenvoorde rdmailings at duif.net
Tue Mar 2 01:45:31 PST 2021
On 3/2/21 9:51 AM, Hernán De Angelis wrote:
> On 2021-03-02 09:48, Alexandre Neto wrote:
>> Might seem obvious, but have you tried using a brand new profile?
> Yes, I just forgot to add that to the description below.
Or even a new profiles_path ?
$ qgis --help
QGIS is a user friendly Open Source Geographic Information System.
Usage: qgis [OPTION] [FILE]
  OPTION:
	[--version]	display version information and exit
	[--snapshot filename]	emit snapshot of loaded datasets to given file
	[--width width]	width of snapshot to emit
	[--height height]	height of snapshot to emit
	[--lang language]	use language for interface text (changes existing override)
	[--project projectfile]	load the given QGIS project
	[--extent xmin,ymin,xmax,ymax]	set initial map extent
	[--nologo]	hide splash screen
	[--noversioncheck]	don't check for new version of QGIS at startup
	[--noplugins]	don't restore plugins on startup
	[--nocustomization]	don't apply GUI customization
	[--customizationfile path]	use the given ini file as GUI customization
	[--globalsettingsfile path]	use the given ini file as Global Settings (defaults)
	[--authdbdirectory path] use the given directory for authentication database
	[--code path]	run the given python file on load
	[--defaultui]	start by resetting user ui settings to default
	[--hide-browser]	hide the browser widget
	[--dxf-export filename.dxf]	emit dxf output of loaded datasets to given file
	[--dxf-extent xmin,ymin,xmax,ymax]	set extent to export to dxf
	[--dxf-symbology-mode none|symbollayer|feature]	symbology mode for dxf output
	[--dxf-scale-denom scale]	scale for dxf output
	[--dxf-encoding encoding]	encoding to use for dxf output
	[--dxf-map-theme maptheme]	map theme to use for dxf output
	[--take-screenshots output_path]	take screen shots for the user documentation
	[--screenshots-categories categories]	specify the categories of screenshot to be used (see QgsAppScreenShots::Categories).
	[--profile name]	load a named profile from the users profiles folder.
	[--profiles-path path]	path to store user profile folders. Will create profiles inside a {path}\profiles folder
	[--version-migration]	force the settings migration from older version if found
	[--openclprogramfolder]		path to the folder containing the sources for OpenCL programs.
	[--help]		this text
	[--]		treat all following arguments as FILEs
So:
qgis --profiles-name /tmp/superclean
I would not know if this would help... but just in case
Richard
More information about the QGIS-Developer mailing list
