[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Hernán De Angelis variablestarlight at gmail.com
Tue Mar 2 03:19:11 PST 2021
On 2021-03-02 10:51, Richard Duivenvoorde wrote:
> On 3/2/21 10:41 AM, Hernán De Angelis wrote:
>> On 2021-03-02 10:21, Nyall Dawson wrote:
>>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
>>> <variablestarlight at gmail.com> wrote:
>>>> Hi,
>>>> I wrote about this a few days ago in the user list but I still have the
>>>> problem and can find neither a cause nor a solution. I thus post it in
>>>> this list in the hope that some developer may have a hint on what is
>>>> going wrong here.
>>> Double check that you have the gdal python packages installed
>> Thanks for this,
>> from osgeo import gdal
>> just works, so I guess it is installed.
> What is the value of
> BINDINGS_GLOBAL_INSTALL
> in your compile config?
The value is "YES"
> Looks like something is not picked up with your install.
Agree
> What if you run qgis 31.8 from the 'output/bin' dir in your build directory?
Behaves just the same
> If all fails I would (I think) compile and set CMAKE_INSTALL_PREFIX in some local dir in your HOME
> I did in ~/bin/qgis_/3.18/debug (for debug build):
> And create a startup script like
> export LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
> export PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
> export QGIS_DEBUG=0
> # passing ALL parameters to qgis bin
> # eg to be able to call a certain translation
> # qgis --lang nl
> ~/bin/qgis_/3.18/debug/bin/qgis "$@"
Thanks, will think about this and try it.
Thank you again for your ansers. I see I have a sort of linking/library
problem. GRASS is installed and GRASS modules are compiled but then
these do not appear either in the menu.
/Hernán
> Suc6
More information about the QGIS-Developer mailing list
