[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Tim Sutton tim at kartoza.com
Tue Mar 2 15:10:30 PST 2021
Hi
Can you check if you have python-psycopg2 installed on your system? I had a
similar issue a month or two back which was fixed by installing it. (Thanks
for the nudge Nyall).
Regards
Tim
On Tue, Mar 2, 2021 at 11:19 AM Hernán De Angelis <
variablestarlight at gmail.com> wrote:
> On 2021-03-02 10:51, Richard Duivenvoorde wrote:
> > On 3/2/21 10:41 AM, Hernán De Angelis wrote:
> >> On 2021-03-02 10:21, Nyall Dawson wrote:
> >>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
> >>> <variablestarlight at gmail.com> wrote:
> >>>> Hi,
> >>>> I wrote about this a few days ago in the user list but I still have
> the
> >>>> problem and can find neither a cause nor a solution. I thus post it in
> >>>> this list in the hope that some developer may have a hint on what is
> >>>> going wrong here.
> >>> Double check that you have the gdal python packages installed
> >> Thanks for this,
> >> from osgeo import gdal
> >> just works, so I guess it is installed.
> > What is the value of
> > BINDINGS_GLOBAL_INSTALL
> > in your compile config?
> The value is "YES"
> > Looks like something is not picked up with your install.
> Agree
> > What if you run qgis 31.8 from the 'output/bin' dir in your build
> directory?
> Behaves just the same
> > If all fails I would (I think) compile and set CMAKE_INSTALL_PREFIX in
> some local dir in your HOME
> > I did in ~/bin/qgis_/3.18/debug (for debug build):
> > And create a startup script like
> > export LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
> > export PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
> > export QGIS_DEBUG=0
> > # passing ALL parameters to qgis bin
> > # eg to be able to call a certain translation
> > # qgis --lang nl
> > ~/bin/qgis_/3.18/debug/bin/qgis "$@"
> Thanks, will think about this and try it.
> Thank you again for your ansers. I see I have a sort of linking/library
> problem. GRASS is installed and GRASS modules are compiled but then
> these do not appear either in the menu.
> /Hernán
> > Suc6
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://kartoza.com to find out about open source:
 * Desktop GIS programming services
 * Geospatial web development
* GIS Training
* Consulting Services
Tim is a member of the QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210302/86f04990/attachment.html>
More information about the QGIS-Developer mailing list
