[QGIS-Developer] Voronoi tool missing from processing, what could be wrong?
Nyall Dawson nyall.dawson at gmail.com
Tue Mar 2 15:12:11 PST 2021
On Wed, 3 Mar 2021 at 09:10, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> Can you check if you have python-psycopg2 installed on your system? I had a similar issue a month or two back which was fixed by installing it. (Thanks for the nudge Nyall).
Ah -- that was the one!  I thought it was gdal for some reason...
flaky memory :)
We should really investigate why this caused a silent failure to show
the algorithms instead of an error...
Nyall
> Regards
> Tim
> On Tue, Mar 2, 2021 at 11:19 AM Hernán De Angelis <variablestarlight at gmail.com> wrote:
>> On 2021-03-02 10:51, Richard Duivenvoorde wrote:
>> > On 3/2/21 10:41 AM, Hernán De Angelis wrote:
>> >> On 2021-03-02 10:21, Nyall Dawson wrote:
>> >>> On Tue, 2 Mar 2021 at 18:34, Hernán De Angelis
>> >>>> Hi,
>> >>>> I wrote about this a few days ago in the user list but I still have the
>> >>>> problem and can find neither a cause nor a solution. I thus post it in
>> >>>> this list in the hope that some developer may have a hint on what is
>> >>>> going wrong here.
>> >>> Double check that you have the gdal python packages installed
>> >> Thanks for this,
>> >> from osgeo import gdal
>> >> just works, so I guess it is installed.
>> > What is the value of
>> > BINDINGS_GLOBAL_INSTALL
>> > in your compile config?
>> The value is "YES"
>> > Looks like something is not picked up with your install.
>> Agree
>> > What if you run qgis 31.8 from the 'output/bin' dir in your build directory?
>> Behaves just the same
>> > If all fails I would (I think) compile and set CMAKE_INSTALL_PREFIX in some local dir in your HOME
>> > I did in ~/bin/qgis_/3.18/debug (for debug build):
>> > And create a startup script like
>> > export LD_LIBRARY_PATH=~/bin/qgis_/3.18/debug/lib/:/usr/lib/grass78/lib/
>> > export PYTHONPATH=~/bin/qgis_/3.18/debug/share/qgis/python:$PYTHONPATH
>> > export QGIS_DEBUG=0
>> > # passing ALL parameters to qgis bin
>> > # eg to be able to call a certain translation
>> > # qgis --lang nl
>> > ~/bin/qgis_/3.18/debug/bin/qgis "$@"
>> Thanks, will think about this and try it.
>> Thank you again for your ansers. I see I have a sort of linking/library
>> problem. GRASS is installed and GRASS modules are compiled but then
>> these do not appear either in the menu.
>> /Hernán
>> > Suc6
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
> Tim is a member of the QGIS Project Steering Committee
More information about the QGIS-Developer mailing list
