[QGIS-Developer] WITH_PDAL and WITH_EPT doubt
Alexandre Neto senhor.neto at gmail.com
Wed Mar 3 00:46:23 PST 2021
Hello again,
Does this mean that, if entwine isn't present in the system, the
compilation won't fail or complaint, but some functionality will be missing?
Should I include entwine as a dependency for 3.18.0 on conda-forge?
Thanks,
Alexandre
A quarta, 3/03/2021, 03:40, Alexandre Neto <senhor.neto at gmail.com> escreveu:
> Great, thanks!
> A quarta, 3/03/2021, 02:03, Nyall Dawson <nyall.dawson at gmail.com>
> escreveu:
>> On Wed, 3 Mar 2021 at 11:59, Alexandre Neto <senhor.neto at gmail.com>
>> wrote:
>> > Hi,
>> > I am trying to add point cloud support to QGIS on conda-forge [0], but
>> I am unsure if I need to use
>> > WITH_PDAL=TRUE
>> yes, you'll need to add this even if you have pdal library available.
>> it defaults to false to avoid breaking the compilation if pdal isn't
>> available (and we want explicit breaks here rather than silently
>> compiling without pdal provider if the library isn't found).
>> > and WITH_EPT=TRUE
>> That defaults to true anyway, so you can omit it if you want.
>> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210303/20220930/attachment.html>
More information about the QGIS-Developer mailing list
