[QGIS-Developer] WITH_PDAL and WITH_EPT doubt
Alexandre Neto senhor.neto at gmail.com
Tue Mar 2 19:40:32 PST 2021
Great, thanks!
A quarta, 3/03/2021, 02:03, Nyall Dawson <nyall.dawson at gmail.com> escreveu:
> On Wed, 3 Mar 2021 at 11:59, Alexandre Neto <senhor.neto at gmail.com> wrote:
> > Hi,
> > I am trying to add point cloud support to QGIS on conda-forge [0], but I
> am unsure if I need to use
> > WITH_PDAL=TRUE
> yes, you'll need to add this even if you have pdal library available.
> it defaults to false to avoid breaking the compilation if pdal isn't
> available (and we want explicit breaks here rather than silently
> compiling without pdal provider if the library isn't found).
> > and WITH_EPT=TRUE
> That defaults to true anyway, so you can omit it if you want.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210303/4e7e369b/attachment.html>
More information about the QGIS-Developer mailing list
