[QGIS-Developer] Compilation error with 'master'
Jorge Gustavo Rocha jgr at di.uminho.pt
Tue Mar 16 03:04:38 PDT 2021
Hi Bjoern,
Are you using PROJ from packages or a compiled version by yourself? Are
you using PROJ 8 or a former version?
You should have proj_experimental.h available at PROJ_INCLUDE_DIR.
Try to locate where you have proj_experimental.h and set
PROJ_INCLUDE_DIR to it.
cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug
-DPROJ_INCLUDE_DIR=/usr/local/include ../QGIS
If needed, you can also define PROJ_LIBRARY, if not in a default path.
-DPROJ_LIBRARY=/usr/local/lib/libproj.so ../QGIS
Try not to mix versions of PROJ libraries. Delete all dangling former
versions.
I hope it helps. Regards,
Jorge Gustavo
Às 09:26 de 16/03/21, pathmapper escreveu:
> Hi,
> if I try to compile QGIS with latest master (commit 8731c7e) it fails with:
> QGIS/src/core/qgscoordinatetransform_p.cpp:26:10: fatal error:
> proj_experimental.h: Datei oder Verzeichnis nicht gefunden
>  #include <proj_experimental.h>
> compilation terminated.
> ("Datei oder Verzeichnis nicht gefunden" -> "file or folder not found")
> I'm on Debian Buster and compiling the 'release-3_18' branch (commit
> d740a22) works flawlessly with my setup.
> Any idea how to fix this?
> Cheers,
> Bjoern
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Gabinete 3.29 (Piso 3)
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
More information about the QGIS-Developer mailing list
