[QGIS-Developer] Compilation error with 'master'
pathmapper pathmapper at posteo.de
Fri Mar 19 22:05:47 PDT 2021
Thanks a lot Jorge Gustavo, yes, I was using PROJ from packages (5.2.0)
as described in
https://github.com/qgis/QGIS/blob/master/INSTALL.md#33-install-build-dependencies
Upgrading to Debian testing (bullseye) solved this issue for me.
On 16.03.2021 11:04, Jorge Gustavo Rocha wrote:
> Hi Bjoern,
> Are you using PROJ from packages or a compiled version by yourself? Are
> you using PROJ 8 or a former version?
> You should have proj_experimental.h available at PROJ_INCLUDE_DIR.
> Try to locate where you have proj_experimental.h and set
> PROJ_INCLUDE_DIR to it.
> cmake -G Ninja -DCMAKE_BUILD_TYPE=Debug
> -DPROJ_INCLUDE_DIR=/usr/local/include ../QGIS
> If needed, you can also define PROJ_LIBRARY, if not in a default path.
> -DPROJ_LIBRARY=/usr/local/lib/libproj.so ../QGIS
> Try not to mix versions of PROJ libraries. Delete all dangling former
> versions.
> I hope it helps. Regards,
> Jorge Gustavo
> Às 09:26 de 16/03/21, pathmapper escreveu:
>> Hi,
>> if I try to compile QGIS with latest master (commit 8731c7e) it fails
>> with:
>> QGIS/src/core/qgscoordinatetransform_p.cpp:26:10: fatal error:
>> proj_experimental.h: Datei oder Verzeichnis nicht gefunden
>>  #include <proj_experimental.h>
>> compilation terminated.
>> ("Datei oder Verzeichnis nicht gefunden" -> "file or folder not
>> found")
>> I'm on Debian Buster and compiling the 'release-3_18' branch (commit
>> d740a22) works flawlessly with my setup.
>> Any idea how to fix this?
>> Cheers,
>> Bjoern
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
More information about the QGIS-Developer mailing list
