[QGIS-Developer] REST API for QGIS processing tool
David Marteau dmarteau at 3liz.com
Mon Mar 22 10:48:55 PDT 2021
Le 22/03/2021 à 18:26, Prem Kumar a écrit :
> Hi Team,
> Im afraid to make a comment but the installation instructions in the
> github are not specifically referring the integration of service and
> the qgis installation and its modules. I have tried installing
> py-qgs-wps on linux machine using archive tar file and ended up
> incompatibility issue between python version - qgis installation and
> the service.
> If it’s not more of an effort, can you please guide me to any
> installation instructions? Thanks
Can you be more specific about the error your are facing ? if that's
about py-qgs-wps then you should open an issue on github.
> -Prem
> On Thu, 25 Feb 2021 at 7:44 PM, Prem Kumar <prem.netgis at gmail.com
> <mailto:prem.netgis at gmail.com>> wrote:
>     HI Nyall and René-Luc,
>     Thank you very much for the pointers, much appreciated. Looks to
>     me, a lot to learn some good stuff. Will let you know how it goes.
>     -Prem
>     On Thu, Feb 25, 2021 at 6:59 PM René-Luc Dhont <rldhont at gmail.com
>     <mailto:rldhont at gmail.com>> wrote:
>         Le 24/02/2021 à 23:27, Nyall Dawson a écrit :
>         > Look into the "WPS" standard. There's even an existing
>         server for
>         > this: https://github.com/3liz/py-qgis-wps
>         <https://github.com/3liz/py-qgis-wps>
>         Thanks Nyall to pointing it.
>         Prem, If you are interested in a REST API, implementing the
>         OGC API
>         Processes standard is  being considered for py-qgis-wps
>         * https://github.com/opengeospatial/ogcapi-processes/
>         <https://github.com/opengeospatial/ogcapi-processes/>
>         * https://ogcapi.ogc.org/processes/
>         <https://ogcapi.ogc.org/processes/>
>         py-qgis-wps is based on Tornado and any contributions are welcome.
>         René-Luc
>         > Nyall
>         > _______________________________________________
>         > QGIS-Developer mailing list
>         > QGIS-Developer at lists.osgeo.org
>         <mailto:QGIS-Developer at lists.osgeo.org>
>         > List info:
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>         > Unsubscribe:
>         List info:
>         Unsubscribe:
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210322/0e520835/attachment.html>
More information about the QGIS-Developer mailing list
