[QGIS-Developer] FeatureRequest: make Page properties (portrait/landscape) easy(ier) accessible
Harrissou delazj at gmail.com
Mon Mar 29 08:19:06 PDT 2021
Hi Richard,
Some discussion at https://github.com/qgis/QGIS/issues/26237 or  https://github.com/qgis/QGIS/issues/25803 and there might be more references in the repo. With the rationale of the current situation (as you found) and some suggestions that may cross yours...
PS: The current behavior is documented (in early days) at https://docs.qgis.org/3.16/en/docs/user_manual/print_composer/overview_composer.html#working-with-the-page-properties ...
Regards,
Harrissou
Le 29 mars 2021 16:44:48 GMT+02:00, Richard Duivenvoorde <rdmailings at duif.net> a écrit :
>Hi Devs,
>I'm not so much of a report/layout maker, so last week I had to create
>a simple (map only) pdf, but really could not find how to change my
>page from Landscape to Portrait...
>Today somebody contacted me with exact the same question: "I used it
>earlier, and now I cannot find 'the button' anymore"...
>What would be the intuitive place to access the page props (most
>notably off course orientation/size)?
>The *Layout* properties-tab/menu (to me most intuitive) is probably not
>showing it because you can have several pages to one layout and they
>can have different page properties (I found out).
>So some (theoretical) options:
>- does a 'page' have 'Item Properties'? Because that one is empty now?
>Would it be easy to add it there?
>- would it be possible to add it to the 'Guides' tab? Because that one
>already has a 'Page' dropdown, so.. maybe add Page properties there?
>- maybe add another tab (like Guides) named 'Pages', and a page
>dropdown there and then the props per page?
>Ah wait... if you have a layout with several (different oriented)
>pages, and you select the context menu 'Page properties', the Page
>properties ARE SHOWN in the 'Item Properties'???
>Does the (empty) layout page has some signal when you click on it? So a
>click on the empty sheet would reveal the same 'Item Properties' as the
>'Page Properties'-context menu shows?
>Or is there some (technical) reason this is not possible?
>If not possible, anybody has a (easy implementable) for this? As my
>gutfeeling is there are more people searching for this :-)
>Regards,
>_______________________________________________
>QGIS-Developer mailing list
>QGIS-Developer at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210329/c79cd76f/attachment.html>
More information about the QGIS-Developer mailing list
