[QGIS-Developer] FeatureRequest: make Page properties (portrait/landscape) easy(ier) accessible
Bourdon, Jean-François (DIF) Jean-Francois.Bourdon at mffp.gouv.qc.ca
Mon Mar 29 08:03:05 PDT 2021
Happy to see that I'm not alone.
Currently, one needs to right-click on the empty page and then choose Page Properties... then the tab Item Properties on the right panel activate with the all the parameters needed. Like you Richard, I'll be looking at first in the Layout tab as, to me, the page itself is more linked to the layout than to a specific item. Hovewer, if there is a good reason to not put it in the Layout tab, either a new exclusive Page tab could be added or an item named Page could be permanently placed in the Items list.
Jean-François Bourdon, ing.f.
Analyste en télédétection
Direction des inventaires forestiers
Ministère des Forêts, de la Faune et des Parcs
5700, 4e Avenue Ouest, local A-108
Québec (Québec) G1H 6R1
Téléphone : 418 627-8669, poste 704304
jean-francois.bourdon at mffp.gouv.qc.ca
mffp.gouv.qc.ca
-----Message d'origine-----
De : QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> De la part de Richard Duivenvoorde
Envoyé : 29 mars 2021 10:45
À : qgis-developer <qgis-developer at lists.osgeo.org>
Objet : [QGIS-Developer] FeatureRequest: make Page properties (portrait/landscape) easy(ier) accessible
Hi Devs,
I'm not so much of a report/layout maker, so last week I had to create a simple (map only) pdf, but really could not find how to change my page from Landscape to Portrait...
Today somebody contacted me with exact the same question: "I used it earlier, and now I cannot find 'the button' anymore"...
What would be the intuitive place to access the page props (most notably off course orientation/size)?
The *Layout* properties-tab/menu (to me most intuitive) is probably not showing it because you can have several pages to one layout and they can have different page properties (I found out).
So some (theoretical) options:
- does a 'page' have 'Item Properties'? Because that one is empty now? Would it be easy to add it there?
- would it be possible to add it to the 'Guides' tab? Because that one already has a 'Page' dropdown, so.. maybe add Page properties there?
- maybe add another tab (like Guides) named 'Pages', and a page dropdown there and then the props per page?
Ah wait... if you have a layout with several (different oriented) pages, and you select the context menu 'Page properties', the Page properties ARE SHOWN in the 'Item Properties'???
Does the (empty) layout page has some signal when you click on it? So a click on the empty sheet would reveal the same 'Item Properties' as the 'Page Properties'-context menu shows?
Or is there some (technical) reason this is not possible?
If not possible, anybody has a (easy implementable) for this? As my gutfeeling is there are more people searching for this :-)
Regards,
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210329/7cde570e/attachment-0001.html>
More information about the QGIS-Developer mailing list
