[QGIS-Developer] QGIS Docs: ReStructureText flavour?
Alexandre Neto senhor.neto at gmail.com
Wed Mar 31 15:10:07 PDT 2021
As far as I remember, sphinx is based/expands "normal" RST introducing new
directives, so it should be normal that some seems to be missing when you
try to parse them using a rst parser.
Alexandre Neto
A quarta, 31/03/2021, 14:11, DelazJ <delazj at gmail.com> escreveu:
> Hi Jonathan,
> I can't answer whether there's any particular RST flavour behind. What I
> know is that we rely on Sphinx [0] and most of the rules/syntaxes we use
> are picked from them. The docs guidelines [1] also provide some explanation
> on the choice made.
> So, in the Sphinx docs, you can find :ref: [2] and .. only:: [3]
> [0] https://www.sphinx-doc.org/en/master/
> [1] https://docs.qgis.org/3.16/en/docs/documentation_guidelines/index.html
> [2]
> https://www.sphinx-doc.org/en/master/usage/restructuredtext/roles.html#cross-referencing-arbitrary-locations
> [3]
> https://www.sphinx-doc.org/en/master/usage/restructuredtext/directives.html#directive-only
> Hope that clarifies,
> Harrissou
> Le mer. 31 mars 2021 à 14:21, Jonathan Moules <
> jonathan-lists at lightpear.com> a écrit :
>> Hi List,
>> What flavour is the RST behind the QGIS docs? There are quite a few
>> things in here that are syntax erroring all the parsers I'm trying and
>> aren't in the basic RST spec either
>> (https://docutils.sourceforge.io/docs/user/rst/cheatsheet.txt).
>> For example using ":ref:" for internal hyperlinks when the spec says
>> they should be done like this:
>> https://docutils.sourceforge.io/docs/user/rst/quickref.html#internal-hyperlink-targets
>> (there is no "ref" in the specs). Or the `.. only:: html` that starts
>> some files.
>> I tried looking at the QGIS Docs page but I couldn't see anything about
>> what RST standard the docs should be written to. Where can I find the
>> spec?
>> Cheers,
>> Jonathan
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210331/a337b1a6/attachment.html>
More information about the QGIS-Developer mailing list
