[QGIS-Developer] CI broken (MinGW64)
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Sat Oct  2 00:49:49 PDT 2021
> Will be fixed with this: https://github.com/qgis/QGIS/pull/45303
Hi Sandro,
probably this is related... while, now, the MinGW64 Windows build
succeeds, QGIS from the MinGW64 build doesn't run properly and the
Python support results disabled.
Running a recent QGIS (5a572dac) from MinGW64 Windows build artifact,
the following error is reported at the beginning and QGIS doesn't have
the Python support:
Couldn't load SIP module.
Python support will be disabled.
   File "", line 1, in
   File
"C:\Users\giudiceandrea\Downloads\QGIS-Portable_4\lib\python3.10\site-packages\qgis\__init__.py",
line 78, in
     from qgis.PyQt import QtCore
   File
"C:\Users\giudiceandrea\Downloads\QGIS-Portable_4\lib\python3.10\site-packages\qgis\PyQt\QtCore.py",
line 24, in
     from PyQt5.QtCore import *
ModuleNotFoundError: No module named 'PyQt5.sip'
Python version:
3.10.0rc2 (default, Sep 14 2021, 00:00:00) [GCC 11.2.1 20210728 (Fedora
MinGW 11.2.1-3.fc35)]
QGIS version:
3.21.0-Master 'Master', 5a572dac
