[QGIS-Developer] CI broken (MinGW64)
Sandro Mani manisandro at gmail.com
Sat Oct 2 04:06:48 PDT 2021
On 02.10.21 09:49, Andrea Giudiceandrea wrote:
>> Will be fixed with this: https://github.com/qgis/QGIS/pull/45303
> Hi Sandro,
> probably this is related... while, now, the MinGW64 Windows build
> succeeds, QGIS from the MinGW64 build doesn't run properly and the
> Python support results disabled.
> Running a recent QGIS (5a572dac) from MinGW64 Windows build artifact,
> the following error is reported at the beginning and QGIS doesn't have
> the Python support:
> Couldn't load SIP module.
> Python support will be disabled.
> Traceback (most recent call last):
>   File "", line 1, in
>   File
> "C:\Users\giudiceandrea\Downloads\QGIS-Portable_4\lib\python3.10\site-packages\qgis\__init__.py",
> line 78, in
>     from qgis.PyQt import QtCore
>   File
> "C:\Users\giudiceandrea\Downloads\QGIS-Portable_4\lib\python3.10\site-packages\qgis\PyQt\QtCore.py",
> line 24, in
>     from PyQt5.QtCore import *
> ModuleNotFoundError: No module named 'PyQt5.sip'
Hi Andrea
This is fixed in mingw-python-qt5-5.15.4-2.fc36, which adds a dependency
on mingw-python3-PyQt5_sip. So this should be fixed as soon as
mingw-python-qt5-5.15.4-2.fc36 has propagated to the repos.
Sandro
More information about the QGIS-Developer mailing list
