[QGIS-Developer] Boundless (docs) & Central provisioning of QGIS plugins...
Alexandre Neto
senhor.neto at gmail.com
Mon Oct 4 11:46:46 PDT 2021
Yes, I have tested also and the plugins on that folder be one magically
installed on all profiles. Didn't test on a network folder, but should work.
A segunda, 4/10/2021, 18:19, Bourdon, Jean-François (DIF) <
Jean-Francois.Bourdon at mffp.gouv.qc.ca> escreveu:
> It seems that if there is any duplicated plugin (same name) in the default
> profile location and in the directory specified by QGIS_PLUGINPATH, only
> the latter will be loaded. It don't think it's bad, but I think this
> behaviour should be noted.
I believe there's a reason for this. The QGIS_PLUGINPATH main idea is for
developer automatically load plugins under development, so if you are
developing a already installed plugin, the dev one would take precedence.
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211004/431f1fc4/attachment-0001.html>
