[QGIS-Developer] Default QgsFeatureFid ?
Sandro Santilli strk at kbt.io
Fri Oct 15 01:34:48 PDT 2021
While writing unit test for QgsFeatureRequest in core I found
that the filterFid() method for the default-constructed
QgsFeatureRequest returns -1 rather than what a default-constructed
QgsFeatureId() would return (0)
So I've been wondering: *should* a QgsFeatureFid have a default
value of -1 instead ? More generically: does QGIS make any assumption
about *which* special value of QgsFeatureFid means "no fid" ?
If there's no such notion as an "unspecified FID" then I wonder
why QgsFeatureRequest is taking the effort of specifying a default
value of it different from the default, and if there's a good reason
it should probably be documented there.
--strk;
  Libre GIS consultant/developer
  https://strk.kbt.io/services.html
More information about the QGIS-Developer mailing list
