[QGIS-Developer] expected ccache hit ratio on new micro release?
Greg Troxel
gdt at lexort.com
Wed Sep 15 10:21:35 PDT 2021
(If people feel this query belongs on -user, please feel free to tell
me that.)
I maintain the qgis entry in pkgsrc, a multi-OS multi-CPU packaging
system, and use qgis 3.16.x on NetBSD. So I am talkiing below about
NetBSD 9 amd64.
I use ccache, to save compilation time, since in doing packaging I am
often rebuilding X that depends on updated Y, but most of X's
compilations are the same headers and sources. And, I often rebuild a
package after I just built it, to verify I didn't break something, after
making a minor change to the packaging files.
On September 5, I updated the package to 3.16.10 (was behind for no good
reason). I always build, make a package, install it, and then run qgis
from the installed package before pushing the update to the rest of
pkgsrc. So far, it's been smooth, and qgis seems not to have any
NetBSD-specific issues.
Just now I changed the version in the control file to 3.16.11 and am
building. I zeroed stats before and have done only a tiny bit of other
building. So far, ccache reports:
cache directory /home/gdt/.ccache
primary config /home/gdt/.ccache/ccache.conf
secondary config (readonly) /usr/pkg/etc/ccache.conf
stats updated Wed Sep 15 13:16:01 2021
stats zeroed Wed Sep 15 09:17:16 2021
cache hit (direct) 13
cache hit (preprocessed) 80
cache miss 4056
cache hit rate 2.24 %
called for link 94
called for preprocessing 2101
compile failed 14
preprocessor error 26
autoconf compile/link 106
no input file 24
cleanups performed 4
files in cache 206471
cache size 9.0 GB
max cache size 10.0 GB
This means qgis will take about 8h to build, on a machine that was
fairly high end in 2014, with 1 core in use (for heat), and plenty of
RAM. This matches my memory of previous updates.
It surprises me that a bug fix release would have almost hits, but
perhaps there is a version number in a header that every program reads,
and thus every file misses. But I am not arguing that it is a bug, of
course.
I am curious if anyone else uses ccache, and if this is what they see as
well.
Thanks,
Greg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210915/2eec5aa8/attachment.sig>
