[QGIS-Developer] Plugin for Layout
Gal Zsolt zsolt.gal at satelitnt.com
Fri Sep 24 23:04:57 PDT 2021
Hello List!
I like to write a plugin to add map corner coordinates as label to the layout.
I write a python script wich do this.
I make a plugin where I add a menu item to the Qgis main interface. Work. This solution is ugly: I select a menu item to make on action on other window (Layout designer window wiht may layout)!
Now I like to add a menu item to edit menu in the LayoutDesignerInterface?.
Reading the Python Api documentation and the Cookbook I don't understand how to make this.
Can someone help me where to find additional documentation about this?
I Google it without success.
Thanks in advance for any help!
Zsolt
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210925/7d9b69f0/attachment.html>
More information about the QGIS-Developer mailing list
