[QGIS-Developer] Plugin for Layout
Raymond Nijssen r.nijssen at terglobo.nl
Sat Sep 25 00:24:28 PDT 2021
Hi Zsolt,
This code adds a button to the layout toolbar. I don't know of a way to
add things to the layout menu as well.
def designer_opened(designer):
     tb = designer.actionsToolbar()
     action = QAction('Push me!', parent=designer)
     tb.addAction(action)
iface.layoutDesignerOpened.connect(designer_opened)
By the way, you can add a grid to your layout map item and show
coordinates. There a quite many options. Have you looked into that?
Hope this helps,
Raymond
On 25-09-2021 08:04, Gal Zsolt wrote:
> Hello List!
> I like to write a plugin to add map corner coordinates as label to the
> layout.
> I write a python script wich do this.
> I make a plugin where I  add a menu item to the Qgis main interface.
> Work. This solution is ugly: I select a menu item to make on action on
> other window (Layout designer window wiht may layout)!
> Now I like to add a menu item to edit menu in the
> *LayoutDesignerInterface?*.
> Reading the Python Api documentation and the Cookbook I don't understand
> how to make this.
> Can someone help me where to find additional documentation about this?
> I Google it without success.
> Thanks in advance for any help!
> Zsolt
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
