[QGIS-Developer] Problems with MAC and OneDrive
Carlo A. Bertelli (Charta s.r.l.) carlo.bertelli at gmail.com
Mon Apr 4 08:33:09 PDT 2022
Could you please provide some more info about the format of the data? I
think your question does not imply using a DBMS server which I could
suggest in this case. Sharing a file that can be updated on a remote file
system involves some (risky) reaction, but cloud storage is different, it
involves syncronisation and I think it requires some planning and careful
evaluation of the consequences of the choices of every participant in the
workgroup. If you synchronise the empty file towards a non-empty version...
you get an empty file.
Maybe you can recover the work looking to all the revisions of the same
file on Onedrive. Good luck.
c
On Mon, Apr 4, 2022 at 1:57 PM Halle Allen I Lech-Consulting via
QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Dear Developers,
> we have a Client that uses your QGis on MAC and two surfaces. The central
> data Storage is OneDrive.
> That means that that Client works on the Surface when he is externally
> working comes into the „office“ and works on the MAC.
> While being external he cleanly sync the data into the OneDrive Cloud and
> then opens the synced Data with MAC. After a few day the data und the
> databases are completely clean like they were never used.
> Could you help me out?
> Greetings from Germany.
> Schöne Grüße
> Allen Halle
> *Fachinformatiker für Systemintegration*
> Tel:  +49 8231 / 95 888 - 99
> Fax: +49 8231 / 95 888 - 98
> Mail: allen.halle at lech-consulting.de
> Web: http://www.lech-consulting.de/
> [image: cid:image001.jpg at 01D64F95.9C34B670]
> *Schneider & Schwandtner GbR*
> - Lech Consulting -
> Guldenstraße 33
> 86343 Königsbrunn
> Geschäftsführung: Michael Schneider, Roland Schwandtner
> Firmensitz: Königsbrunn
> Gerichtsstand: Augsburg
> USt-IdNr: DE297850929
> *Damit Ihre IT flüssig läuft !*
> Diese E-Mail enthält vertrauliche und/ oder rechtlich geschützte
> Informationen und Anlagen.
> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich
> erhalten haben, informieren Sie bitte sofort den Absender und vernichten
> Sie diese E-Mail.
> Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail sind
> nicht gestattet.
> This e-mail may contain confidential and/ or privileged information. If
> you are not the intended recipient (or have received this e-mail in error)
> please notify the sender immediately and destroy this e-mail.
> Any unauthorized copying, disclosure or distribution of the material in
> this e-mail is strictly forbidden.
> Sie diese E-Mail.
> nicht gestattet.
> Sie diese E-Mail.
> nicht gestattet.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220404/e5b22c34/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220404/e5b22c34/attachment.jpg>
More information about the QGIS-Developer mailing list
