[QGIS-Developer] Building from source using Qt6
Nyall Dawson nyall.dawson at gmail.com
Mon Aug 8 22:13:01 PDT 2022
On Tue, 9 Aug 2022 at 14:15, Paul Burns via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> I am attempting to build qgis from https://github.com.qgis/QGIS. I have been working my way through the dependencies in CMakeLists.txt. I am using QtCreator 7.0.2 based on Qt 6.2.3.
> In the CMakeLists.txt section “# search for Qt”, around line 450, I see that the variable BUILD_WITH_QT6 is set to false.
> Can I use Qt6 to build the current QGIS source?
Basically no. It's a wip which is still a considerable time off.
Nyall
More information about the QGIS-Developer mailing list
