[QGIS-Developer] Building from source using Qt6
Paul Burns
paulburns at simplexity.com.au
Mon Aug 8 23:05:00 PDT 2022
Thanks Nyall.
Ok I'll revert back to Qt5. Is there a preferred Qt5 version?
Is there a design document, or anything that describes/summarises the structure of the source code, which functionality is where etc.
Paul
-----Original Message-----
Sent: Tuesday, 9 August 2022 2:43 PM
To: Paul Burns <paulburns at simplexity.com.au>
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] Building from source using Qt6
On Tue, 9 Aug 2022 at 14:15, Paul Burns via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> I am attempting to build qgis from https://github.com.qgis/QGIS. I have been working my way through the dependencies in CMakeLists.txt. I am using QtCreator 7.0.2 based on Qt 6.2.3.
> In the CMakeLists.txt section “# search for Qt”, around line 450, I see that the variable BUILD_WITH_QT6 is set to false.
> Can I use Qt6 to build the current QGIS source?
Basically no. It's a wip which is still a considerable time off.
Nyall
