[QGIS-Developer] Building from source: Missing /src/core/qgsmeshcalcparser.hpp
paulburns paulburns at simplexity.com.au
Wed Aug 17 01:14:56 PDT 2022
Hi Mattias. Thanks. For Flex Bison I cloned winflexbison and compiled an .exe and put that plus the header in a directory in my project. I pointed cmake to the directory which only has the exe and the header and this satisfied cmake but I am guessing this us not enough? Thanks Paul.Sent on the go with Vodafone
-------- Original message --------From: Matthias Kuhn <matthias at opengis.ch> Date: 17/8/22  5:12 pm  (GMT+09:30) To: Paul Burns <paulburns at simplexity.com.au> Cc: qgis-developer at lists.osgeo.org Subject: Re: [QGIS-Developer] Building from source: Missing /src/core/qgsmeshcalcparser.hpp Hi Paul,Did you install flex and bison and are these found by cmake?RegardsMatthiasOn Wed, Aug 17, 2022 at 9:23 AM Paul Burns via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:I am attempting to build my qgis solution now that I have all my dependencies installed and the root CMakeLists.txt is parsing. Using QtCreator and Qt5.15. Target = windows. Qtcreator compiler Output complains with: AutoGen error-------------Info error in info file"D:/e-qgis-qt515/build-QGIS-Desktop_Qt_5_15_2_MinGW_64_bit-Debug/src/core/CMakeFiles/qgis_core_autogen.dir/AutogenInfo.json":The header file "BIN:/src/core/qgsmeshcalcparser.hpp" does not exist. In /src/core there are no qgsmesh….. files at all. In my (D:/e-qgis-qt515/QGIS) /src/core/mesh, there isqgsmeshcalcparser.yy, but no qgsmeshcalcparser.hpp Any ideas please? Thanks Paul  _______________________________________________
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
QFIELD 2.0 IS HERE! - Hold the power of QGIS in your hand - learn more - get it now
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220817/0883ea3b/attachment.htm>
More information about the QGIS-Developer mailing list
