[QGIS-Developer] Building from source: Missing /src/core/qgsmeshcalcparser.hpp
Matthias Kuhn matthias at opengis.ch
Wed Aug 17 02:14:17 PDT 2022
Hi Paul,
Check if the BISON_EXECUTABLE in your CMakeCache.txt file in your build
folder builds to the correct executable.
Cheers
On Wed, Aug 17, 2022 at 10:15 AM paulburns <paulburns at simplexity.com.au>
wrote:
> Hi Mattias. Thanks. For Flex Bison I cloned winflexbison and compiled an
> .exe and put that plus the header in a directory in my project. I pointed
> cmake to the directory which only has the exe and the header and this
> satisfied cmake but I am guessing this us not enough? Thanks Paul.
> Sent on the go with Vodafone
> -------- Original message --------
> From: Matthias Kuhn <matthias at opengis.ch>
> Date: 17/8/22 5:12 pm (GMT+09:30)
> To: Paul Burns <paulburns at simplexity.com.au>
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [QGIS-Developer] Building from source: Missing
> Hi Paul,
> Did you install flex and bison and are these found by cmake?
> Regards
> Matthias
> On Wed, Aug 17, 2022 at 9:23 AM Paul Burns via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> I am attempting to build my qgis solution now that I have all my
>> dependencies installed and the root CMakeLists.txt is parsing. Using
>> QtCreator and Qt5.15. Target = windows.
>> Qtcreator compiler Output complains with:
>> AutoGen error
>> Info error in info file
>> "D:/e-qgis-qt515/build-QGIS-Desktop_Qt_5_15_2_MinGW_64_bit-Debug/src/core/CMakeFiles/qgis_core_autogen.dir/AutogenInfo.json":
>> The header file "BIN:/src/core/qgsmeshcalcparser.hpp" does not exist.
>> In /src/core there are no qgsmesh….. files at all.
>> In my (D:/e-qgis-qt515/QGIS) /src/core/mesh, there is
>> qgsmeshcalcparser.yy, but no qgsmeshcalcparser.hpp
>> Any ideas please?
>> Thanks Paul
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [image: https://qfield.org/get/] <https://qfield.org/get/>
> QFIELD 2.0 IS HERE! - Hold the power of QGIS in your hand - learn more
> <https://www.opengis.ch/2022/04/05/qfield-2-0-is-here/> - get it now
> <https://qfield.org/get>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220817/1aae24a8/attachment-0001.htm>
More information about the QGIS-Developer mailing list
