[QGIS-Developer] Specifying minimum Qt version for plugin?
Matthias Kuhn
matthias at opengis.ch
Tue Jan 11 08:31:40 PST 2022
Hi Hannes,
There is no such thing available currently.
If you know which OS your users run on you can use the QGIS version as an
indicator.
Matthias
On Tue, Jan 11, 2022 at 5:18 PM Johannes Kröger (WhereGroup) <
johannes.kroeger at wheregroup.com> wrote:
> Hi list,
> is there a way to specify the minimum Qt version for a plugin? I saw
> nothing in metadata.txt which would be the preferrable way because
> otherwise I'd need to throw a dialog into the user's face after
> installing. :\
> Thanks, Hannes
> Johannes Kröger / GIS-Entwickler/-Berater
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Schon gewusst?
> In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
> und berichten aus unserem Experten-Alltag:
> https://wheregroup.com/blog/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220111/d44c7e53/attachment.html>
