[QGIS-Developer] Specifying minimum Qt version for plugin?
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Wed Jan 12 07:52:26 PST 2022
Hey Matthias,
that is an interesting idea. Is there an overview of the official
builds' versions and Qt versions somewhere? For now I decided to check
the Qt version in the plugin's run method. It's not the best as the user
will only find out when they want to run it, but it is only meant as a
temporary fix anyways.
Thanks, Hannes
Am 11.01.22 um 17:31 schrieb Matthias Kuhn:
> Hi Hannes,
> There is no such thing available currently.
> If you know which OS your users run on you can use the QGIS version as
> an indicator.
> Matthias
> On Tue, Jan 11, 2022 at 5:18 PM Johannes Kröger (WhereGroup)
> <johannes.kroeger at wheregroup.com
> <mailto:johannes.kroeger at wheregroup.com>> wrote:
>     Hi list,
>     is there a way to specify the minimum Qt version for a plugin? I saw
>     nothing in metadata.txt which would be the preferrable way because
>     otherwise I'd need to throw a dialog into the user's face after
>     installing. :\
>     Thanks, Hannes
>     Johannes Kröger / GIS-Entwickler/-Berater
>     WhereGroup GmbH
>     Grevenweg 89
>     20537 Hamburg
>     Germany
>     Tel: +49 (0)228 / 90 90 38 - 36
>     Fax: +49 (0)228 / 90 90 38 - 11
>     www.wheregroup.com <http://www.wheregroup.com>
>     Geschäftsführer:
>     Olaf Knopp, Peter Stamm
>     Amtsgericht Bonn, HRB 9885
>     Schon gewusst?
>     In unserem Blog geben wir Tipps & Tricks zu
 Open-Source-GIS-Software
>     und berichten aus unserem Experten-Alltag:
>     https://wheregroup.com/blog/ <https://wheregroup.com/blog/>
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>     Unsubscribe:
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
www.wheregroup.com
Geschäftsführer:
Schon gewusst?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220112/aa271e29/attachment.html>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220112/aa271e29/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220112/aa271e29/attachment.sig>
More information about the QGIS-Developer mailing list
