[QGIS-Developer] Specifying minimum Qt version for plugin?
Germán Carrillo carrillo.german at gmail.com
Wed Jan 12 09:00:10 PST 2022
Hallo Johannes,
here you have an example of version checks in the *classFactory()* itself
(file *__init__.py* of your plugin).
https://github.com/SwissTierrasColombia/Asistente-LADM-COL/blob/master/asistente_ladm_col/__init__.py
Regards,
Germán ( *mit Akzent :) *)
El mié, 12 ene 2022 a las 10:52, Johannes Kröger (WhereGroup) (<
johannes.kroeger at wheregroup.com>) escribió:
> Hey Matthias,
> that is an interesting idea. Is there an overview of the official builds'
> versions and Qt versions somewhere? For now I decided to check the Qt
> version in the plugin's run method. It's not the best as the user will only
> find out when they want to run it, but it is only meant as a temporary fix
> anyways.
> Thanks, Hannes
> Am 11.01.22 um 17:31 schrieb Matthias Kuhn:
> Hi Hannes,
> There is no such thing available currently.
> If you know which OS your users run on you can use the QGIS version as an
> indicator.
> Matthias
> On Tue, Jan 11, 2022 at 5:18 PM Johannes Kröger (WhereGroup) <
> johannes.kroeger at wheregroup.com> wrote:
>> Hi list,
>> is there a way to specify the minimum Qt version for a plugin? I saw
>> nothing in metadata.txt which would be the preferrable way because
>> otherwise I'd need to throw a dialog into the user's face after
>> installing. :\
>> Thanks, Hannes
>> Johannes Kröger / GIS-Entwickler/-Berater
>> WhereGroup GmbH
>> Grevenweg 89
>> 20537 Hamburg
>> Germany
>> Tel: +49 (0)228 / 90 90 38 - 36
>> Fax: +49 (0)228 / 90 90 38 - 11
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
>> Schon gewusst?
>> In unserem Blog geben wir Tipps & Tricks zu Open-Source-GIS-Software
>> und berichten aus unserem Experten-Alltag:
>> https://wheregroup.com/blog/
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> johannes.kroeger at wheregroup.comwww.wheregroup.com
> Geschäftsführer:
> Schon gewusst?
> und berichten aus unserem Experten-Alltag:https://wheregroup.com/blog/
   |\__
(:> __)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
https://twitter.com/GeoTux2 <http://twitter.com/GeoTux2>
<http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220112/50d8223d/attachment-0001.html>
More information about the QGIS-Developer mailing list
