[QGIS-Developer] CDash still not working
Sandro Santilli strk at kbt.io
Fri Jun 10 12:00:31 PDT 2022
On Fri, Jun 10, 2022 at 06:30:43PM +0200, Alessandro Pasotti via QGIS-Developer wrote:
> Hi,
> CDash submission from CI does work but the page shows no tests and no
> failures, this makes it very hard to understand why some image_diff
> tests are failing.
I filed this issue yesterday:
https://github.com/qgis/QGIS/issues/48939
Maybe you want to add your case there too ?
Incidentally: is the produced .html supposed to be left locally, when
running the tests locally ? We now have a .ci/run_tests.sh script that
is supposed to run all the tests in the same docker envionment as the
CI so it would be handy to debug this.
Beside, in order for .ci/run_tests.sh to work in a worktree merging
this pull request would be needed: https://github.com/qgis/QGIS/pull/48752
(your review is welcome, to finalize it)
--strk;
  Libre GIS consultant/developer
  https://strk.kbt.io/services.html
More information about the QGIS-Developer mailing list
