[QGIS-Developer] CDash still not working
Alessandro Pasotti apasotti at gmail.com
Fri Jun 10 12:11:14 PDT 2022
On Fri, Jun 10, 2022 at 9:00 PM Sandro Santilli <strk at kbt.io> wrote:
> On Fri, Jun 10, 2022 at 06:30:43PM +0200, Alessandro Pasotti via QGIS-Developer wrote:
> > Hi,
> > CDash submission from CI does work but the page shows no tests and no
> > failures, this makes it very hard to understand why some image_diff
> > tests are failing.
> I filed this issue yesterday:
> https://github.com/qgis/QGIS/issues/48939
Sorry I missed that, thank you for fixing it.
> Maybe you want to add your case there too ?
Done.
> Incidentally: is the produced .html supposed to be left locally, when
> running the tests locally ? We now have a .ci/run_tests.sh script that
> is supposed to run all the tests in the same docker envionment as the
> CI so it would be handy to debug this.
> Beside, in order for .ci/run_tests.sh to work in a worktree merging
> this pull request would be needed: https://github.com/qgis/QGIS/pull/48752
> (your review is welcome, to finalize it)
I'll have a look, thank you.
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
More information about the QGIS-Developer mailing list
