[QGIS-Developer] Zip errors in artefact builds
Alexis R.L. alroyliz0 at gmail.com
Tue Jun 28 13:28:15 PDT 2022
Greetings Richard,
I'm referring to the ones made by the MingW64 windows build, apologies for
not clarifying beforehand.
I use the one in my own fork to make custom build but nothing that could
affect the zip handling. Though I recall having a similar issue with the
ones on the official repo. I'm not sure if if's something related to a bad
library associated with the build. I'll try to dig deeper.
Alex
Le mar. 28 juin 2022 à 08:14, Richard Duivenvoorde via QGIS-Developer <
qgis-developer at lists.osgeo.org> a écrit :
> On 6/28/22 13:00, Alexis R.L. via QGIS-Developer wrote:
> > Greetings everyone,
> > I wanted to check if anyone had the same error or had a clue of the
> cause.
> > When using artefact build made from a qgis branch I always have issues
> when opening files from the recent menu or the provided list. Zip always
> return error 28 (or 90% of the time) but when I drag & drop a project in
> the app, it opens perfectly fine.
> > I would assume the error might come from something strange with the zip
> library. Tried to find error code and couldn't find them online.
> Hi Alex,
> Which 'artefact' are you using, and on which OS?
> (I think you mean the Windows build artefacts, but wanting to make that
> clear)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220628/f7c3061b/attachment.htm>
More information about the QGIS-Developer mailing list
