[QGIS-Developer] Zip errors in artefact builds
Richard Duivenvoorde rdmailings at duif.net
Tue Jun 28 05:14:20 PDT 2022
On 6/28/22 13:00, Alexis R.L. via QGIS-Developer wrote:
> Greetings everyone,
> I wanted to check if anyone had the same error or had a clue of the cause.
> When using artefact build made from a qgis branch I always have issues when opening files from the recent menu or the provided list. Zip always return error 28 (or 90% of the time) but when I drag & drop a project in the app, it opens perfectly fine.
> I would assume the error might come from something strange with the zip library. Tried to find error code and couldn't find them online.
Hi Alex,
Which 'artefact' are you using, and on which OS?
(I think you mean the Windows build artefacts, but wanting to make that clear)
Regards,
More information about the QGIS-Developer mailing list
