[QGIS-Developer] Unexpected results from GPKG table query using executeSql()
Raymond Nijssen r.nijssen at terglobo.nl
Thu Mar 31 09:09:25 PDT 2022
Hi devs,
I'm working on a plugin that connects to a custom table (without
geometry) in a GPKG. When I'm sending queries to it, I keep on getting
unexpected results. Somehow the id field is missing, sometimes it
appears twice (!). And this seems to be different between QGIS 3.10 and
3.25. (I think it changed since 3.22).
Here is a piece of my code:
fn = '/path/to/test.gpkg'
md = QgsProviderRegistry.instance().providerMetadata('ogr')
conn = md.createConnection(fn, {})
q = 'select * from test_table;'
qr = conn.executeSql(q)
print(qr) # No id field in result
Before diving into the QGIS code I'd like to check if this is the way to
go. Or should i use another way to query that GPKG (SQLite) db?
Kind regards,
Raymond
More information about the QGIS-Developer mailing list
