[QGIS-Developer] Unexpected results from GPKG table query using executeSql()
Alessandro Pasotti apasotti at gmail.com
Thu Mar 31 09:15:00 PDT 2022
Hi Raymond,
your code looks good.
Can you provide a test file?
There are some test in core here:
https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsproviderconnection_ogr_gpkg.py
On Thu, Mar 31, 2022 at 6:09 PM Raymond Nijssen via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi devs,
> I'm working on a plugin that connects to a custom table (without
> geometry) in a GPKG. When I'm sending queries to it, I keep on getting
> unexpected results. Somehow the id field is missing, sometimes it
> appears twice (!). And this seems to be different between QGIS 3.10 and
> 3.25. (I think it changed since 3.22).
> Here is a piece of my code:
> fn = '/path/to/test.gpkg'
> md = QgsProviderRegistry.instance().providerMetadata('ogr')
> conn = md.createConnection(fn, {})
> q = 'select * from test_table;'
> qr = conn.executeSql(q)
> print(qr) # No id field in result
> Before diving into the QGIS code I'd like to check if this is the way to
> go. Or should i use another way to query that GPKG (SQLite) db?
> Kind regards,
> Raymond
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
QCooperative:  www.qcooperative.net
ItOpen:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220331/ad1ec7b7/attachment.html>
More information about the QGIS-Developer mailing list
