[QGIS-Developer] Compile QGIS in docker
David Marteau dmarteau at 3liz.com
Sat Oct 22 08:54:19 PDT 2022
I use and compile Qgis desktop and server on Docker on a daily basis.
Docker on Windows or Osx relies on linux vm, so basically, you should do
- almost - anything that
you can do on Linux but  my expérience has taught me that the processe
is much smoother on Linux.
However, as Richard said, WSL on Windows works rather well with Docker
and should provide you wih real linux
experience
About qgis ready to use docker image you may find several up to date
flavors:
- https://hub.docker.com/r/qgis/qgis
- https://hub.docker.com/r/3liz/qgis-platform (no desktop - server only)
If your goal is to compile Qgis, you should go with multi-stage building
process
and I can tell more about this if you want.
You will find ready made images with build dependencies:
https://hub.docker.com/r/qgis/qgis3-build-deps
Or some recipies for achieving this on latest Debian/Ubuntu:
https://github.com/3liz/docker-qgis-build
Regards,
David
Le 22/10/2022 à 16:49, Richard Duivenvoorde via QGIS-Developer a écrit :
> On 10/22/22 16:25, Paul N via QGIS-Developer wrote:
>> Is it possible to compile QGIS in docker on windows system.
>> Any clue.
> What is your use-case?
> - Desktop or Server?
> - Host = Windows, but container = ?
> There are ready to use QGIS-Server images, others know better which
> one is most up to date (@others..)
> If you just want to compile in a Debian/Ubuntu/whatever, off course
> you can: a container is/can be a full fledged Linux machine.
> We also experimented with Running QGIS-Desktop on a container on a
> Linux host running X.
> Not sure if that is possible on a Windows host though, and you will
> probably have some container/permission issues... though I've been
> flabbergasted with the recent capabilities of the Linux sub system on
> Windows... ( but to be clear: just use Linux :-) ).
> Anyway: what is it that you want to try?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
