[QGIS-Developer] Broken coordinate/distance/area calculation tests
Harrissou s.
delazj at gmail.com
Sun Oct 30 14:11:10 PDT 2022
So nobody knows why the tests that used to pass and succeeded on Thursday, suddenly failed on Friday? Or should I just adjust the tests outputs and stop bothering?!?
https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml
Greetings,
Harrissou S.
Le 28 octobre 2022 08:10:19 GMT+02:00, "Harrissou s." <delazj at gmail.com> a écrit :
>Hi,
>I am wondering if the method for area/distance calculation has changed again in master or if the issue is in some transformation accuracy changes.
>In QGIS docs, we are getting failing tests for calculation we did not touch the underlying data for years.
>See starting from https://github.com/qgis/QGIS-Documentation/actions/runs/3339628288/jobs/5530428647#step:6:703
>Regards,
>Harrissou
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221030/691583b8/attachment.htm>
