[QGIS-Developer] Broken coordinate/distance/area calculation tests
Nyall Dawson nyall.dawson at gmail.com
Sun Oct 30 15:20:19 PDT 2022
On Fri, 28 Oct 2022 at 16:10, Harrissou s. via QGIS-Developer
<qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I am wondering if the method for area/distance calculation has changed again in master or if the issue is in some transformation accuracy changes.
> In QGIS docs, we are getting failing tests for calculation we did not touch the underlying data for years.
> See starting from https://github.com/qgis/QGIS-Documentation/actions/runs/3339628288/jobs/5530428647#step:6:703
Was there any corresponding updates to the test infrastructure? This
looks to me like a proj library update has been installed.
Nyall
> Regards,
> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
