[QGIS-Developer] Broken coordinate/distance/area calculation tests
Delaz J delazj at gmail.com
Sun Oct 30 16:11:51 PDT 2022
Thanks Nyall. No, no changes I'm aware of:
https://github.com/qgis/QGIS-Documentation/commits/master
master itself is(was?) green. It is the latest PR
<https://github.com/qgis/QGIS-Documentation/pull/7849> that fails, and
given that it touches nothing related to tests, I suspect the culprit is
somewhere in the qgis docker image we pull.
Regards,
Harrissou
Le 30/10/2022 à 23:20, Nyall Dawson a écrit :
> On Fri, 28 Oct 2022 at 16:10, Harrissou s. via QGIS-Developer
> <qgis-developer at lists.osgeo.org>  wrote:
>> Hi,
>> I am wondering if the method for area/distance calculation has changed again in master or if the issue is in some transformation accuracy changes.
>> In QGIS docs, we are getting failing tests for calculation we did not touch the underlying data for years.
>> See starting fromhttps://github.com/qgis/QGIS-Documentation/actions/runs/3339628288/jobs/5530428647#step:6:703
> Was there any corresponding updates to the test infrastructure? This
> looks to me like a proj library update has been installed.
> Nyall
>> Regards,
>> Harrissou
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221031/64ff304d/attachment.htm>
More information about the QGIS-Developer mailing list
